What is this cr4p all over my engine!!!!?
Hi Folks
Can any one help/advise me on the following issue? Had the
06 for about three weeks and after the first week I took a look at the engine
compartment. To my surprise there was a thick greenish oily fluid splattered
all over the top of my engine. I wiped most of this off without thinking as to
what it might be. However, there is still plenty of it left (see pic). The
insulation material that is attached to the inside of the bonnet is sodden with
this fluid also. There is an unpleasant but very very slight odour from it and,
at times when I use the air conditioning, it gives off a dreadful smell similar
to this substance only much much stronger. Since I wiped it off, it hasn’t
returned, so if there was some sort of leak, I’m sure it would have shown itself
again. Any ideas? It’s due its 1k service on Tuesday and I intend to have it
looked at, but would like a heads up seeing that I am clueless!
Thanks
John
I'd guess its some sort of protective coating they put over the engine when new?! I hope its nothing more sinister than that anyway!!
Cheers,
Grant
Cheers,
Grant
thats what i thought but says its all over the sound deadning stuff under the bonnet too?
but the stuff does smell bad
Its waxoyl got it all over my car when it was new. In fact it's still there working a treat. They re-apply it on your 1st and 3rd body service as well. Nothing to worry about mate.
Don't worry about that....Go to Halfords and get CD2 engine degreaser and sealer and all will be great..
One cleaned engine bay below after using CD2
Cheers mate!
No probs[;)]
Yup it is a protective coating they put on , attracts all the dirt and looks awfull wery quickly though, dont worry about it. It cleans off very easily with engine cleaner.
I presume that it is applied for transoprt etc as the salt air is very corrosive to metals even though the car is stowed on a car deck of a car carrier coming from Japan.
Graeme
Thanks mate! It's going in for service on Tuesay, so maybe they will tidy it up.
J
J
No they won't.....you need to do it yourself[;)]
