jamie_wood Posted May 23, 2006 Posted May 23, 2006 Petay, Its pretty much just plug n' play if its the right fitting kit for your car. Split the Ign loom and fit the Y section. There will be a signal from your Handbrake and two earths if they are still the same as the older ones. Not sure if yours has voltage readouts, boost, speed, etc. Give it a go. Disconnect the battery before you start the job remember []
fai17 Posted May 23, 2006 Author Posted May 23, 2006 Where does the 2 black cables go Jamie? I see the y plug thingy. I'll get a pic posted up and you can show me.
fai17 Posted May 24, 2006 Author Posted May 24, 2006 Here is the pic. 1.Where does the 2 black cable goes? 2.Where does the orange and purple goes? 3.Where does the white and the other black cable goes?
bigdavie Posted May 24, 2006 Posted May 24, 2006 pedro speak to wrc no1 (wullie) he made me a loom to fit my car so i'm positive he can help you with your's !
st3ph3n Posted May 24, 2006 Posted May 24, 2006 Peter, did you buy it with the appropriate wiring harness?
