1488 Posted May 5, 2006 Posted May 5, 2006 Alright muckers, how's it hanging. Anyone know how to get the passenger front door card off on a 2000 UK turbo. There's something rolling around in the bottom of the door that sounds like a marble and its driving me mental.
robert_harding Posted May 5, 2006 Posted May 5, 2006 tis a doddle mate. if i can remember. you need to remove the screws from behind the Square caps.....if tha makes sense. remove the trim from arond the door lever, you dont need to remove the lever itself, but you can if you wish. you have to fiddle out the elctric window switch panel, i think, from the front,pull rearwards then up. then unplug it from the wiring loom. pull the doorcard away from the door at the bottom and sides, be careful with this. then lift the door card upwards..you will see the clips that the top of the door card was behind..check there isnt any attched to your door cards. this is from memory, as i dont that year anymore.[]
vicki Posted May 5, 2006 Posted May 5, 2006 sounds like a marble and its driving me mental. let us know what it was []
1488 Posted May 9, 2006 Author Posted May 9, 2006 The plot thickens. Ive taken the door cards off front and back and found nothing but the noise is still there, somewhere. On the upside I found the child lock switch on the back door, which I wish I found 6 months ago.
