need help
I think mine is T'd off in the pipe that runs to the dump valve.
Its simply a matter of running that pipe through the bulkhead to the gauge and then wiring it ithat in to the lighting circult to illuminate it.
You can take a light feed from any of the switches. Just follow the connections to see which ones feed the bulbs.
When It comes to routing cables I always use a bit of curtain rail wire to find the rooute and then tape my wire/pipe to the end, and pull it through into the car.
You can also use a meter or so of the thinner coax type cable.
