Check Engine Light
Folks,
Driving home tonight, after about 10 miles i am coming off a roundabout and floor it in 2nd, hold til about 6500 and jus as i shift up to 3rd i get a CEL....
Car is still running fine, still getting boost although i only went to about 3500rpm's just in case....
Any idea's, how do i find out what threw it up?
Chris
I've had my cel on for 4 yrs, full decat brings it on, filter might, does the car stall at all? maybe the neutral position senor, EGT sensor, lamda or crankshaft senor!
Hope you get it fixed.
RR
Guess thats really my only option..... its £27.50 plus VAT to get it plugged in....
Is this the only place i can get it done?
May be clutching at straws here but could it be worth resetting the ECU to see whether it throws it up again?
ive had this engine light on on my car a few times, have you had it re-mapped?
mines has and sometimes when pushin it on high boost and at night i was gettin it, it was coming on and off now and again had my car checked and it was showing misfires but the car was running fne
ive a wrx and i have an STI 8 intercooler and was gettin too much air had the fuel pump uprated and its seems to have stopped
Is AWD in Perth?
Yes Dougster i know i need to get joined up properly, nice hint!! [:D]
Arron,
Mine isn't remapped, only thing i've done recently is remove the intake resonator and put in a cold air feed from the inner wing, wonder if its related!?!??!
If your attending the Glasgow meet tomorrow, I will bring along a Laptop and OBDII Reader. and can read from most Scoobys 98 onward. I will not charge you anything but a token donation to the RB fundrasing would be welcome.
Ed
It more than likely be your cold air feed giving a mis reading. Best to get it checked out, mine flashed 15 times thins morning, go tomorrow to get it checked out.
Ricey
