help plz
hi would like some advice on a knocking sound coming from my engine,  was out in i 2nite when all of a sudden i heard the noise,  any body herd this or had it hapn 2 them, i have an sti v3 1996, thanks graeme
What sort of knocking? coming from the bottom of the engine? Dont drive it whatever you do, get a good mechanic to have a listen. My big end bearings went last weekend, V5 type r, not good[:'(]
Col.
Mine isnt knocking on tickover but as soon as you rev it,it knocks a fair bit, think it is saveable with a rebuild. If its knocking really bad you will prob need a new short block.
i have a knoking noise comimg from my engine stripped the sump off after a compression test on the cylinders, no 2 was low and when the sump came off found the big end bearing has worn away, resulting in a nasty mess to my con rod and my crank case, i have a new engine on order. to much ware to salvage it, and would cost the same to put new parts in as it wou;d to buy a refurb short block
hi was just wondering if any body out there would happen 2 know where i could pick up a complete sti v3 1996 engine and gearbox with low miles think il just swap engines over if u do know plz get in touch thanks graeme
Sorry to hear your news, but it does sound suspiciously like a big end away. Mine went 3 years back (sti 5), and it was actually a blown piston, which subsequently took out the big end. I chose the "replace engine" route, as the repair option was too much of a potential black-hole!! Cost me 2k for the engine back then, but prices have dropped significantly since then.
Try Glenburgie Subaru in Forres. He's usually got a few sti's in stock.
www.glenburgie-subaru.co.uk
HTH
DAve
  • 4 weeks later...
hi finaly got a new engine for my car, thanks 2 all those who left me ideas, i was just wondering with me geting a new engine will i need 2 get this one re_maped or will it be fine with the program in the powerfc thanks graeme
just when i thought things were geting better with me having a new engine my mechanic was changing things over and we discover that the engine is the wrong one and thats after waiting 2 weeks on the engine being sent out i give up
hi found out it was number 2 piston bearing that went,  was wondering if anyboby knows the best place 2 but a big end bearing kit and heads bolt was thinking about rebuilding my old engine any help would be great thanks graeme
  • 2 weeks later...
finaly got my engine sorted out after a lot of bother with wrong engines getn sent 2 me, get it on monday went for a new sti short block, just like 2 give a big thanks 2 liam at glenburgie - subaru for his help and all the other people who had given me ideas many thanks graeme
