Help
PTOMO
As mentioned above stick with the standard re-circ dv. This topic has been discussed a thousand times on scoobynet so just do a search for dv on there and you will have plenty of info, the main concensous being that atmospheric dv's are a waste of time and can induce bore wash through over fuelling. The std re-circ dv that Subaru fit is a well engineered piece of kit, much better than the plastic Bosch ones that some manufacturers fit.
As for performance there was a programme on Men and Motors a while back and they tested the std and aftermarket dvs on a blobeye STI on a rolling road back to back, they found an aftermarket dv to be leaking 1 psi of boost over the std fit dv therefore loosing power[:D
Couldnt answer that, bore wash is a long term affect basically unburnt fuel in the cylinders can get forced down the sides of the pistons and wash/dilute/contaminate the oil and cause damage over a period of time to the cylinder walls. Dont take this as gospel though as it is just info from scoobynet and there can be a lot of scare mongering on there at times as we all know[:D]!
I was going to get an atmospheric dv for mine when I first got it but decided to spend the money on other parts that I would get some performance gain from, I found when I had a dv on my previous car that after a while I got fed up of the noise.
Atmospheric dv's can cause idle probs though, I used to have a Punto GT3 with a bailey atmospheric dv on it and that would sometimes hunt at idle, I got a Collins twin piston dv and the car ran alot better (not as good as it did with the std plastic bosch re-circ dv though but it sounded good[:)])!
  Quote
  Quote
He doesn't post much but when he does it's quality stuff![:D]
25 and counting[:)]
Even I look a post whore compared to that tally PMSL.
Andy
Subaru still don't recommend one if they do why don't they fit it?
all to do with emissions regulations
Come on Rob admit it you're just a boy racer![:D]
