chris_c201 Posted November 29, 2005 Posted November 29, 2005 Alrighty Folks, Couple of questions, Where is the oil filter located on a bugeye, i assume its underneath as i took a quick look under the bonnet and couldn't see it... Secondly - Where is the best place to buy an oil filter for the car in and around the glasgow area? Halfrauds don't stock them..... Oh ye, also, where will i get the sump plug washer? Cheers!
gordon_kerr Posted November 29, 2005 Posted November 29, 2005 << Alrighty Folks, Couple of questions, Where is the oil filter located on a bugeye, i assume its underneath as i took a quick look under the bonnet and couldn't see it... Secondly - Where is the best place to buy an oil filter for the car in and around the glasgow area? Halfrauds don't stock them..... Oh ye, also, where will i get the sump plug washer? Cheers! >> ok the oil filter is indeed underneath, on a ramp its easy to spot on the buggy, you need to remove the plastic underbelly and et voila , there it is, usually when you buy the oil filter the copper ring comes with it, should cost you no more than £7, 4 and a half litres approx of oil needed when changing the filter
