dirtmonkey Posted November 18, 2005 Posted November 18, 2005 i am thinking of getting a prodrive 330mm brake upgrade, has any one had one. Or know if they are any good. also are they gona b any better than my sti 4 pots? Any info would be good
granby Posted November 19, 2005 Posted November 19, 2005 Why do you need big brakes you don't drive fast enough I'm running out the door now, coat in hand
granby Posted November 19, 2005 Posted November 19, 2005 << I'm running out the door now, coat in hand >> I'm back, it's bloody cold out there
riceboy Posted November 19, 2005 Posted November 19, 2005 I have the Prodrive kit fitted to my 94wrx. They are a vast improvement over the standard 2 pots that I had. The only downside to them is the initial price and replacement parts cost. £200 for pads (ferodo ds2500 with prodrive stamped on the back, I got mine from ASPerformance £130ish) and £400+ for a pair of discs (although most brake companies can sell you separate discs and bells from £300 and you can then reuse the bells each time and just change the discs for approx £200). Hope this helps. Nathan
dirtmonkey Posted November 20, 2005 Author Posted November 20, 2005 cheers 4 the info riceboy. grandy its all about the look, the sti 4 pots and standard disk look lost under the new rims. And the old ones are on the way out (well thats what i told my girlfriend and i am sticking 2 it)
tony_cousins Posted November 20, 2005 Posted November 20, 2005 Go get a God Speed big brake conversion, Granby will tell you how goos they are
