Fault code 85
Never knew there was a 85
Is that what is flashing up when you join the 2 black plugs under the dash together.
Type Ravensblade into Google and it will take you to a website that will give you the full list of Subaru OBD2 codes
Grant
im not using a obd2 code reader just the onboard diagnostics thru the flashing CEL by connecting the black plugs so cant match the 85 with any obd2 codes
ECU codes
Bit of a weird one here
There is no 85 listed on the full Subaru range wide list
The small list of codes at the top is for the Turbo models and the large one at the bottom covers the full range from Justy to SVX
Grant
The only ref I can find for code 85 is in OBD2 P0085-Exhaust Valve Control Solenoid Circuit Low. But I would check with Subaru before spending any major money. If your car is fitted with a OBD2 connector I have the interface and software to check the codes for you. Would not be a problem.
Ed
I have a couple of jobs in clydebank and bearsden tomorrow send me a email will some contact details and I will team up with you. email me at ed@ed-209.com
Ed
