rear brake replacement
You don't necessarily need to slacken it off. If it does require it, then the adjuster is just behind the handbrake lever. You'll have to unscrew the surround.
What are you putting on the back? If you go too serious, then you may benefit from fitting a bias valve.
I had the calipers off but couldn't shift the discs even with bolts screwed in on the front of the disc.
just replacing 70k old worn discs.
