Hoses For An Oil Catch Can
Can anyone tell me what spec of hoses are required for an oil catch can and roughly how much hosing is required? It is not a return to sump one.
Thanks
Chris
You can buy oil line rubber from fleabay. No oil passes through it, just contaminated fumes. Tanks I've used in the past have always had a clear tube on the side so you know when they need emptied. Edit: just looked and so does yours. Maybe I don't understand your type of installation though. Remember, I'm new to Scoobs Chris :)
Edited by bombsquad
I have looked at silicon hose and did a wee google search and people use oil/fuel line hose also. Just not too sure what to get. Silicon hose is quite expensive.
Any advice I can get is always welcomed.
Chris
Online it states, generally, 15mm ports for a turbo car. Use 13mm ID silicone hoses to provide a tight fit.
Silicone hoses, in a variety of colours are buttons on ebay, did you jet jubes with it.
The only issue I see with clear hoses is they will look crap, all manky.
Hope that helps mate
With the car going on track occasionally now I prefer to be safe than sorry. I have researched this quite a bit and majority of research points to it being a good idea.
