ciaranrb5 Posted August 19, 2012 Posted August 19, 2012 (edited) I recently purchased P1 #494 which = Project 494 Have decided seeing as the build number isn't that high a number why not use it as a target Car was bought with knocking engine so that will have to be replaced Parts I have to fit so far Engine Fully forged 2.1 CDB Big port JDM AVCS heads Un-equal Gruppe s headers Billet fuel rails 960cc injectors Reversed inlet manifold HKS intercooler Walbro lift pump Bosch 044 transfer pump Swirl pot Drivetrain/brakes 5 speed 3.9 DCCD box with straight cut PPG gearkit Plated R180 3.9 rear diff Stage 5 uprated driveshaft shop rear R180 shafts AP 330mm 6 pots Brembo 2 pot rear brakes Suspension Set of BC coilovers 24mm rear whiteline anti roll bar 22mm front anti roll bar Whilteline adjustable lateral arms Whilteline anti lift kit Whiteline subframe brace I still require a turbo and ECU Looking at SC46 and will be running a syvecs ECU Aim is a sub 60 second lap of Knockhill and to be my 1/4 mile PB of 11.68 More pics when the engine comes out later in the month Edited August 19, 2012 by ciaranrb5
colin_ross Posted August 19, 2012 Posted August 19, 2012 Dunno about the laptime but you should beat that quarter mile time easily if you're willing to be brutal with the launch.
ciaranrb5 Posted August 20, 2012 Author Posted August 20, 2012 Dunno about the laptime but you should beat that quarter mile time easily if you're willing to be brutal with the launch. Have no got alot of experience of knockhill but managed 62 with the old car with 2.1 and 20g so hopefully with some training, improved spool and better suspension i should be able to do it. As for 1/4 mile I have no problem launching it. Was doing a full bore 6k launch when I ran 11.68 and have the transmission to handle it
colin_ross Posted August 20, 2012 Posted August 20, 2012 Was doing a full bore 6k launch when I ran 11.68 and have the transmission to handle it Is that the ppg kit? I have the same and found the limits of one of the standard parts the kit doesn't replace doing the same
ciaranrb5 Posted August 20, 2012 Author Posted August 20, 2012 Is that the ppg kit? I have the same and found the limits of one of the standard parts the kit doesn't replace doing the same What is that? I will take my chances
colin_ross Posted August 20, 2012 Posted August 20, 2012 That was a drop gear. It lives in the centre diff and takes power to the rear wheels. Snapped it clean in two and left me with the fastest FWD subaru at crail that day.
ciaranrb5 Posted August 20, 2012 Author Posted August 20, 2012 That was a drop gear. It lives in the centre diff and takes power to the rear wheels. Snapped it clean in two and left me with the fastest FWD subaru at crail that day. I have a spare set of drop gears so not so concerned. If it breaks it breaks will just have to make it better so it doesn't break
ciaranrb5 Posted September 3, 2012 Author Posted September 3, 2012 Well engine issue is still not really identified. It seems to only knock when cornering. Car drives normally but the idle is poop I have the forged 2.1 in my old car so it's coming out and will be fitted into the P1 with AVCS heads Started stripping the old car for the engine coming out this week Must remember in future that you need to release the refrigerant gas in the air conditioning before undoing connections Will be fitting the reverse inlet manifold manifold so air con will be going in the bin.
fai17 Posted September 4, 2012 Posted September 4, 2012 You don't need air con in this country plus it slow you done
ciaranrb5 Posted September 23, 2012 Author Posted September 23, 2012 Well picked up the AVCS heads. Never actually got around to pulling the 2.1 out of my old car yet. Plan however is to pull out the 2.1 and stick it on a stand and clean it up and paint it. Pull the engine out of the P1. Full respray due to now having own paint shop in the garage ( don't worry also have a mate who is a paint sprayer to actually paint it ) Engine bay will also get painted to match the external colour of the car. Have the wheels blasted and the painted (colour yet undecided graphite or gold? Clean up all brackets, inlet manifold etc and paint them. Strip all the suspension parts off the car have them grit blasted then paint everything and polly bush the whole car. Then rebuild it all with all the tasty bits I have and hopefully we will have a mint 450-500bhp P1. I appologise for the lack of pics. All will start when i get home 2nd of october and the car will.....will....will be back on the road for my 30th at the end of March
lewisscoob Posted September 23, 2012 Posted September 23, 2012 Anthracite or black for wheels, you put gold wheels on and it'll look like a type r trying to be a p1. Keeping the external colour sonic blue?
ciaranrb5 Posted September 23, 2012 Author Posted September 23, 2012 Anthracite or black for wheels, you put gold wheels on and it'll look like a type r trying to be a p1. Keeping the external colour sonic blue? Of course staying sonic Blue. Some P1's came with gold wheels as standard. Could go bright silver
lewisscoob Posted September 23, 2012 Posted September 23, 2012 The bright flitter is nice on the P1. Didn't know some came with gold wheels, a factory option I guess.
ciaranrb5 Posted September 24, 2012 Author Posted September 24, 2012 The bright flitter is nice on the P1. Didn't know some came with gold wheels, a factory option I guess. Yes they came with 17" or 18" wheels in gold, anthracite or silver
ciaranrb5 Posted October 17, 2012 Author Posted October 17, 2012 Well a little update Old car on the ramp in the new shed engine on its way out Engine on the stand An heads off and all looks good PPG box is also off and will be rebuilt over the winter forgot to take any pics though. Back to work for a couple of week on tue. Will get the engine out of the P1 next time I am home
ciaranrb5 Posted October 24, 2012 Author Posted October 24, 2012 busy busy! not realy only a days work
scooby222 Posted October 24, 2012 Posted October 24, 2012 Blimey! thats more than youve managed in the last three years - did someone slip you a gallon of red bull for brekkie?
ciaranrb5 Posted October 25, 2012 Author Posted October 25, 2012 Blimey! thats more than youve managed in the last three years - did someone slip you a gallon of red bull for brekkie? No new garage 100 yards from the house gave me motivation. Next is P1 engine out and full respray plus a little bit of attention to detail when it comes to the underbody
cullenmin Posted October 26, 2012 Posted October 26, 2012 Keep the updates coming Ciaran, whats the plans when( big when lol) the project is finished? Rich
ciaranrb5 Posted October 26, 2012 Author Posted October 26, 2012 Keep the updates coming Ciaran, whats the plans when( big when lol) the project is finished? Rich It will never be finished but plan is safe 400bhp for next year till the new engine is ready for 2014
cullenmin Posted October 27, 2012 Posted October 27, 2012 It will never be finished but plan is safe 400bhp for next year till the new engine is ready for 2014 You going to be doin knockhill next year at 400 then? I'm hoping to get a few trackdays in so maybe see you there. I know what you mean, these things are never finished
ciaranrb5 Posted October 28, 2012 Author Posted October 28, 2012 You going to be doin knockhill next year at 400 then? I'm hoping to get a few trackdays in so maybe see you there. I know what you mean, these things are never finished Yes defo. May even just put the 2.1 back together with the VF28 just so its finished by the spring
lewisscoob Posted October 29, 2012 Posted October 29, 2012 VF28 on a 2.1, that will be an absolute hoot to drive! Just about no lag and about 320-330hp!
