burgy_51_ Posted June 23, 2011 Posted June 23, 2011 Does anyone know a good place to get a sun visor made up that u can design yourself ? And how hard is it to fit mudflaps , the new ones is a different fit from the prodrive ones I have on just now , would a garage fit them and how much do u think they would charge ? Cheers John
frenchy Posted June 23, 2011 Posted June 23, 2011 Scoobyparts in Bedford I believe have their own Vinyl machine, give Tim a call and he'll be able to help, sorry can't answer the flap question Or www.scoobyparts.com
lupuss Posted June 24, 2011 Posted June 24, 2011 I have the Kaylan Scoobyworld WRC mudflags and they were pretty easy to fit - just had to remove a few screws and replace with the supplied bolt clips and bolt on as far as I remember. Just don't tighten the bolts too tight, or you will damage your trim around the front wheel arch (as I did...) I then had to drill a couple of holes in the front wheel arch to screw the bracket in place, and I plastered the area with underseal before screwing the screws into the holes and then painted over the screws with more underseeal to make sure no water gets in... That's the only hard part really - the rear ones are easier than the fronts. The scoobyworld kit came with very good instructions too. You only need to jack up the front of the car to remove the front wheel - one side at a time... You might find it's harder getting your only flaps off than fitting new ones - I did!! Had to saw through 6 bloody stainless steel bolts... lup.
