hosstheboss Posted October 20, 2010 Share Posted October 20, 2010 Anyone changed one of these? A guy at work needs to replace his and not sure whats involved? Link to comment
StewartyBoy Posted October 20, 2010 Share Posted October 20, 2010 (edited) Hi Mate, The bearings are'nt tapered so will need to be pressed in and out the hub. You'll also need circlip pliers. In the new bearing pack you'll get 2 seals, the bearing and a circlip. Removing the hub itself should'nt be too difficult. Edited October 20, 2010 by StewartyBoy Link to comment
hosstheboss Posted October 21, 2010 Author Share Posted October 21, 2010 Hi Mate, The bearings are'nt tapered so will need to be pressed in and out the hub. You'll also need circlip pliers. In the new bearing pack you'll get 2 seals, the bearing and a circlip. Removing the hub itself should'nt be too difficult. Cheers mate, appreciate the advice! Link to comment
