Changing Headlight Bulbs
Need to replace blown bulbs - 2005 Blobeye ... do I need to remove battery / air duct or should I just remove the lamp unit?
I last did it 5 years ago and my memory ain't what it used to be ;)
Many tas ...
i'm sure it can be done without removing anything... you just need to find someone with small hands...
if you loosen the lamp, be careful not to scrape it across the bumper.
5t.
Job done.
Loosened the battery clamp on the passenger side and removed the air scoop on the drivers side. Simple enough when its not raining !!!
Need to check the passenger side is seated correctly as the beam height looks a bit different.
Thanks Phil MC & 5t.
Job done.
No probs, thinking back I reckon I only had to loosen the light assembly to get access to the sidelight filaments.
Glad you're all sorted ;) .
