mikeyboyswindon Posted June 11, 2010 Posted June 11, 2010 rite lets start from the begining one day just driving along car just cut out no warning no lights just stopped like someone turned it off started her back up all fine went to give it a bit it cut then went then cut kept doing it turned car off tried again and ran fine real;ly strange then i was just crawling along she cut i turned ingnition off and on whilst rolling carried on lol so thought i would put plugs together see what fault i get well i got maf come back so ok got another one changed plugs and new leads happy days not its still doing it any ideas please im lost now
edmondo Posted June 11, 2010 Posted June 11, 2010 I think this is a problem for our resident Guru - Big D.
petenofear Posted June 15, 2010 Posted June 15, 2010 top of my head i would say it was the crank sencer
mikeyboyswindon Posted June 15, 2010 Author Posted June 15, 2010 hi its a 98 uk2000 no mods cobra alarm mite be worth having a new crank sensor and try that
"NIGHT PROWLER" Posted June 15, 2010 Posted June 15, 2010 loose connection some were or dirty fuel worth changing the filter?
petenofear Posted June 17, 2010 Posted June 17, 2010 pm me your address mate and i will post you a crank sensor down to you its been sat the the garage for some time but i no it was a good one when removed if it works then you can have it if not just post it back to me pete
tazman Posted June 17, 2010 Posted June 17, 2010 possible faulty immobiliser? I'd go with what he said, sound very similar to what happened to my wagon. It would cut out and after a few miutes would start up and run fine for a couple of months and then for no reason cut out.....................thought it might be a knackered fuel pump so had a Walbro 255 fitted. tw months later cut out again. Any hows after chatting with the local specialist and folks on the Hants forum we decided to by-pass the fuel pump side the wiring in the immoboliser and ran fine after that
mikeyboyswindon Posted June 17, 2010 Author Posted June 17, 2010 cheers people for ideas anyone know { ive just checked oil level and its just over the limit would that make a differance
