frankyboy Posted May 24, 2010 Posted May 24, 2010 think i have found out why the car is idling funny missing bolt on the ICV so now think its the starter thats going on it anybody know how to check to see if the starter is gubbed it turns over for about 3-5 seconds before it actually fires up
jae Posted May 24, 2010 Posted May 24, 2010 is it a classic, as mine is a bit slow, but I need a new battery, it's pretty gubbed
Big 'D' Posted May 24, 2010 Posted May 24, 2010 How many bolts are there on your IACV? There should be 3. Poor starting could be down to a partial blockage in the fuel system or a weak spark due to incorrect gaps or worn electrodes etc If a classic it will worth looking to see if there are any fault codes stored, have a look in the 'How to' thread in the 'Tech section' for instructions on how to do this. It Cheers Iain
arch Posted May 24, 2010 Posted May 24, 2010 (edited) There should be 4 bolts holding the ICV to the inlet manifold. If you can get a meter across the battery see what the voltage drops to when starting, if it dips below 10v your battery is gubbed then at least you can rule that out. Edited May 24, 2010 by Arch
frankyboy Posted May 24, 2010 Author Posted May 24, 2010 (edited) well there is 3 (i thought there was meant to be 4) checked for a code and it was flashing constant so was telling me there was no fault i checked the plugs but they all seemed fine only put them in april think im gonna change the fuel filter see if that makes a difference any intruction on how to change this Edited May 24, 2010 by frankyboy
arch Posted May 24, 2010 Posted May 24, 2010 well there is 3 (i thought there was meant to be 4)checked for a code and it was flashing constant so was telling me there was no fault i checked the plugs but they all seemed fine only put them in april think im gonna change the fuel filter see if that makes a difference any intruction on how to change this What years you car
Big 'D' Posted May 24, 2010 Posted May 24, 2010 What years you car Ok I should have said that if its a V3 or V4 97-98 Impreza there will only be 3 bolts but there are 4 holes on the IACV I am not sure but the older cars may have 4 bolts? Cheers Iain
Big 'D' Posted May 24, 2010 Posted May 24, 2010 Looking at the manual the pre 97 (pre facelift) Impreza IACV has 4 bolts, the 97 - 98 defo only has 3. Cheers Iain
arch Posted May 24, 2010 Posted May 24, 2010 Ok I should have said that if its a V3 or V4 97-98 Impreza there will only be 3 bolts but there are 4 holes on the IACV I am not sure but the older cars may have 4 bolts? Cheers Iain Ian thats the confusion, phase 1 and 1.5 manifolds have 4 bolt ICV's they changed on the phase 2 cars. But that said if there isnt a hole to screw in a 4th bolt then it must be correct
frankyboy Posted May 24, 2010 Author Posted May 24, 2010 Ok I should have said that if its a V3 or V4 97-98 Impreza there will only be 3 bolts but there are 4 holes on the IACV I am not sure but the older cars may have 4 bolts? Cheers Iain its a 1997 R reg wagon gonna try get a meter for the battery see if that shows anything
arch Posted May 24, 2010 Posted May 24, 2010 Dont you just love Subaru, different versions, different pahses and parts differences between them all - nice
Big 'D' Posted May 24, 2010 Posted May 24, 2010 Ian thats the confusion, phase 1 and 1.5 manifolds have 4 bolt ICV's they changed on the phase 2 cars. But that said if there isnt a hole to screw in a 4th bolt then it must be correct Phase 1 has 4 bolts, phase 1.5 has 3 and the IACV was moved to the throttle body on the phase 2. The 97 Impreza defo only has 3 bolts holding the IACV on, there are 4 holes on the IACV but only 3 tappings in the intake manifold. Cheers Iain
frankyboy Posted May 24, 2010 Author Posted May 24, 2010 Phase 1 has 4 bolts, phase 1.5 has 3 and the IACV was moved to the throttle body on the phase 2.The 97 Impreza defo only has 3 bolts holding the IACV on, there are 4 holes on the IACV but only 3 tappings in the intake manifold. Cheers Iain yeah your spot on glad somebody knows my car
Big 'D' Posted May 24, 2010 Posted May 24, 2010 yeah your spot on glad somebody knows my car I have the same engine layout as yours on My V3 (97) Sti Cheers Iain
Big 'D' Posted May 24, 2010 Posted May 24, 2010 Are you running an atmospheric DV? Also what plugs did you fit PFR6B or PFR7B? If you fitted the 7s did you gap them at all? Cheers Iain
arch Posted May 24, 2010 Posted May 24, 2010 Ian you are correct the phase 1.5 manifold has 3 bolt holes but the ICV itself has 4 bolt holes of which the bottom left is not used on the phase 1.5 manifold. The phase 1 and 1.5 ICV's are interchangeable the only difference is the angle of the pipe.
frankyboy Posted May 24, 2010 Author Posted May 24, 2010 Are you running an atmospheric DV?Also what plugs did you fit PFR6B or PFR7B? If you fitted the 7s did you gap them at all? Cheers Iain it was 6s that was put in and never gaped them
Big 'D' Posted May 24, 2010 Posted May 24, 2010 Thats fine, do you have an atmospheric DV fitted? Cheers Iain
frankyboy Posted May 24, 2010 Author Posted May 24, 2010 Thats fine, do you have an atmospheric DV fitted?Cheers Iain dont know what atmospheric means but yeah got a DV fitted
hi_jac Posted May 24, 2010 Posted May 24, 2010 The icv has 4 bolt holes on Franks car and only 3 bolts. As said a new gasket and 4 bolts, put the standard air box back on and clean the maf and take it from there. PM me and let me know how you get on. Good luck.
frankyboy Posted May 24, 2010 Author Posted May 24, 2010 The icv has 4 bolt holes on Franks car and only 3 bolts. As said a new gasket and 4 bolts, put the standard air box back on and clean the maf and take it from there. PM me and let me know how you get on. Good luck. put the standard box back on seems to run a little high when starting her up then goes back down to about 8000 where it sits quite stable just now thanks again mate for the hand today
hi_jac Posted May 24, 2010 Posted May 24, 2010 Np only happy to help, now get that icv 4th bolt in pronto
Big 'D' Posted May 25, 2010 Posted May 25, 2010 Np only happy to help, now get that icv 4th bolt in pronto Well if its a Phase 1.5 V3 (MY97) Impreza please let me know how you get on fitting the 4th bolt as there is NO tapping in the manifold for it Cheers Iain
Guest sti3_lewak Posted May 25, 2010 Posted May 25, 2010 I would agrea with Big D... I have had my IACV off many times and it only has 3bolts. holding it on there is a 4th hole on IACV but not tapping on the intake manilfold. I have a 1997 STI Ver 3. Looked at my mates 1998 and his is the same again
frankyboy Posted May 25, 2010 Author Posted May 25, 2010 somebody has said it could be the head gasket this person is not really reliable but just thought i would ask not loosing fluid power or oil no smokey exhaust
