maxy Posted April 4, 2010 Posted April 4, 2010 working on car saturday and today fitting new turbo and other bits went to start the car flat battery so jump started it ok............... then went for and drive for half hour switched it off and was dead agian anyone have any ideas
billyboystoys Posted April 4, 2010 Posted April 4, 2010 had the same probs with mine off road for 7 days having calipers recond put it all back together battery jumped it took it for a run still flat so bit the bullit and bought a new one no probs now if your battery is older than 5 years buy a new one cheers .billy
maxy Posted April 4, 2010 Author Posted April 4, 2010 had the same probs with mine off road for 7 days having calipers recond put it all back together battery jumped it took it for a run still flat so bit the bullit and bought a new one no probs now if your battery is older than 5 years buy a new one cheers .billy think that might be it alarm is now going off and cant do anything car is an 05 will get a new battery tomorrow cheers billyboystoys
arch Posted April 5, 2010 Posted April 5, 2010 If you have access to a meter check the voltage before you try and start it, probably be sitting around 12v. Then check it again once its running to ensure you have around 14v, that will prove the alternator is working. If you have 14v while running your battery is not holding a charge.
scoob fae ork Posted April 5, 2010 Posted April 5, 2010 If your alt is working it might be worth trying your battery on a trickle charge as if its very low your car prob wont charge it and just put enough power in for the car to run. Check the fluid too if ya can get in to the battery.
arch Posted April 5, 2010 Posted April 5, 2010 (edited) If your alt is working it might be worth trying your battery on a trickle charge as if its very low your car prob wont charge it and just put enough power in for the car to run. Check the fluid too if ya can get in to the battery. To be fair I had to have my battery replaced under warranty, 55 WRX, for the same issue not holding a charge. Edited April 5, 2010 by Arch
