Sump Replacement Required - Where To Take?
Hi all
Noticed a small oil leak under the car a couple of days ago and have discovered that the sump plug is leaking - threads are stripped. ;)
Sump replacement looks like a fairly involved job, so I'm looking for some recommendations as to where to take it to get it done.
Thanks
Corrie
Hi all
Thanks
Corrie
Corrie,
Would it be possible to re-thread (clean the threads) with a tap and die set rather than replace the sump? get them for under a tenner on ebay so, well worth a shout before you head down the sump replacement route.
Gus
Edited by Gus the Bus
yup, as above....
I also have a spare sump (EJ20) lying in the garage you can have for £10 if needs be. Its not pristine, but it doesnt leak.
Cheers. I'll keep that in mind, if the rethread goes wrong.
Corrie
Cheers Gus.
I'm guessing the threads will be goosed, so I'm contemplating taping out to a slightly bigger size and getting a bigger plug.
This is a really common problem - I found loads of hits on Google for this sort of thing. Talk of taping and sealants but I'd like a good solid metal fix if I can.
Thanks
Corrie
