Jon B Posted March 6, 2010 Posted March 6, 2010 just read the fault codes on me classic... got 2 codes from it 23 and 22 does anyone know what these relate to?? ta in advance
BJM Posted March 6, 2010 Posted March 6, 2010 just read the fault codes on me classic...got 2 codes from it 23 and 22 does anyone know what these relate to?? ta in advance 23 - maf sensor 22 - knock sensor I think. Anyone else?
Jon B Posted March 6, 2010 Author Posted March 6, 2010 would these faults be enough to make it think its a kangaroo at anything over 3000 revs?? its spot on when its parked revs no probs...soon as you start driving its ok under 3000 revs anything over it starts kangarooing like feck.... ? seems to be building pressure fine (although not checked with boost gauge)...
dipsy Posted March 6, 2010 Posted March 6, 2010 http://www.jollygreenmonster.com/ecu.asp.htm .Here a list for classic fault codes.Kev
BJM Posted March 6, 2010 Posted March 6, 2010 Yes a faulty maf would allow it to run fine up until the boost comes in.
Jon B Posted March 6, 2010 Author Posted March 6, 2010 next question... is it possible that cleaning the maf may cure it??? if so how do i go about it???
BJM Posted March 6, 2010 Posted March 6, 2010 Yes a faulty maf would allow it to run fine up until the boost comes in. see if this helps http://www.imprezasport.net/forums/index.php?showtopic=785
BJM Posted March 6, 2010 Posted March 6, 2010 I don't think your really suppose to clean them. There supposed to be self cleaning. You coul try electrical solvent. I'd wait for other advice first.
Jon B Posted March 6, 2010 Author Posted March 6, 2010 no probs... regarding the knock sensor can i just dissconnect it and rely on my knocklink to do its job or would i be best replacing it??
BJM Posted March 6, 2010 Posted March 6, 2010 Jon, check this out, http://bbs.scoobynet.com/general-technical...tml#post9261693
Jon B Posted March 6, 2010 Author Posted March 6, 2010 cheers mate hows merc ownership treating you??? you need to let me see your new beast...
