Scoob Wont Start
hi all
had the engine out for the clutch i was fitting along with a service now its all back in it wont start think there is no spark so might have put a plug that doesn't get used in where the good 1 is supposed to go trouble is i cant find any that have the same fitting
anyone (The SIDC Muppet-O-Tron has corrected your lazy use of the English language. Please use English and not text talk on these Forums) shed any light
cheers craigb
Any more detail?
The guys have been great on here helping me out with mine over the last fortnight.
Does it turn over and not catch? Just crank? Start then die? or nothing at all?
Edited by Smiler AS
What model you got? Can you put a plug onto the plug leads to check for a spark? Also when the ignition is swithed on do you hear the fuel pump prime?
The plugs on the loom should only fit the sensor etc they are for so you shouldn't be able to connect the wrong one (iirc). you've prob missed a connector or earth. Check the 2 main plugs at the battery are clean and connected correctly.
You'll probably find it's something daft you've overlooked.
Good luck, Johnny
Edited by JohnnyR6
i have a my93 classic wrx ra and its turning over and can smell petrol but just wont go as far as i can see i have all the connecters in the right places and all earths are in place with good contact
giving me a headache lol
both main plugs are connected properly and in good condition
What did you miss? ;)
Johnny
lol 1 half of the ign module no wonder it wouldnt start only found it by going thru the plugs i had disconnected methodicly and it was the last 1 i looked at doh never mind though its only time
vehicle speed sensor 2 has stopped working though dunno if i have pulled it out the back of the clocks or summit maybe i bumped the sensor i dunno will look the night
cheers craigb
