Leaking Gearbox
Hi guys
experiencing a little gearbox leak, so took the gearbox out earlier this evening and noticed a small triangle shaped hole underneath the shaft. just wondering if this is ment to be here? if not this will be most prob the cause of the problem. Just never noticed this before on the gearbox and looks too perfect to be a crack in the casing.
any help appreciated. pic below for reference.
Are you sure that it is gearbox oil and not engine oil from the plate on the back of the engine behind the clutch?
I have 2 gearboxes in the shed I will go have a look and see if the triangle is on them, I am sure it was on one of them as I remember thinking the same thing when I removed it.
Cheers Iain
Whatever that triangle hole is for it is there for a reason as it is on both the gearboxes I have in the shed, I would check that plate on the back (drivers side) of your engine mate.
Cheers Iain
Thanks for that mate, kinda thought it was to perfectly shaped to be cracked. havent taken clutch off yet so check that tomo.
Thats cool mate, please let us know what you find :lol:
Cheers Iain
found that the bearing seal on engine was leaking - got new ordered
plate you had mention previous was fine but took it off and re-sealed it while I could get at it just so i know its been done. :rotfl:
had originally though it was gearbox because oil was bit low and flywheel n clutch werent sprayed in oil plus thought that hole mentioned above wasnt ment to be there. learn sumit new everyday :rotfl:
cheers again
Stuart
cheers again
Stuart
Glad you got it sorted fella :rotfl:
Cheers Iain
