Jon B Posted February 7, 2010 Posted February 7, 2010 just wondering if there is a right way and a wrong way to refill/bleed the system?? i read somewhere about removing the top rad hose which goes to the filler tank and after filling tank u squeeze bottom hose then cover said pipe(thus creating a vacuum) this pulls the water into the system and bleeds out most of the air... is this right?? or is there an easier way?? other thing is if i leave the cap off the car with it running should the water start to overflow from the tank??? there's no bubbles or anything in it but it does overflow... reason i ask is i've just flushed my collant system through and want to make sure i get all the airlocks out... cheers in advance
StrikE Posted February 7, 2010 Posted February 7, 2010 will do lol please no m8, i was only taking the pee outa poor John http://forums.sidc.co.uk/index.php?showtopic=143411
