Vimmy Posted November 20, 2009 Posted November 20, 2009 Hi Iain, I read somewhere in the myriad of threads in the forums ( I cant find it anywhere) here about the replacement air pipe you made/installed between the air filter and the turbo inlet pipe. I remebmer seeing the picture you put up showing the red pipework, was that a 76mm ID silicone hose you used or wider? I found a few places on fleabay that do similar 45degree hoses and a 76mm one would/should fit nicely. Did you use one of this size or bigger (allowing higher airflow). Also did you have to fit any extra piping to the hose ie a metal/plastic barbed hose connector to cater for the carbon canister air output back to recirc back into the system again? Cheers, Colin
Big 'D' Posted November 20, 2009 Posted November 20, 2009 Hi Iain, I read somewhere in the myriad of threads in the forums ( I cant find it anywhere) here about the replacement air pipe you made/installed between the air filter and the turbo inlet pipe. I remebmer seeing the picture you put up showing the red pipework, was that a 76mm ID silicone hose you used or wider? I found a few places on fleabay that do similar 45degree hoses and a 76mm one would/should fit nicely. Did you use one of this size or bigger (allowing higher airflow). Also did you have to fit any extra piping to the hose ie a metal/plastic barbed hose connector to cater for the carbon canister air output back to recirc back into the system again? Cheers, Colin I dont know off the top of my head mate but you are more than welcome to come over and we can measure the pipes and I will show you how I put it together, also the alloy wishbones are still here too Cheers Iain
Vimmy Posted November 20, 2009 Author Posted November 20, 2009 Ah cool, many thanks Iain, would Sunday or early next week be ok with you, I'm out tonight and away to the Outlaws tomorrow so will be in need of a rather large stiff drink so wont be able to drive We could compare the size of our wishbones then too Cheers, Col
Big 'D' Posted November 20, 2009 Posted November 20, 2009 Ah cool, many thanks Iain, would Sunday or early next week be ok with you, I'm out tonight and away to the Outlaws tomorrow so will be in need of a rather large stiff drink so wont be able to drive We could compare the size of our wishbones then too Cheers, Col I am sure Sunday is fine Cheers Iain
Big 'D' Posted November 20, 2009 Posted November 20, 2009 Is that a meet at your house Iain?!! If you want mate you are always welcome Cheers Iain
myles Posted November 20, 2009 Posted November 20, 2009 What time are you getting together round there, Ill pop across for one of your famous brews!
Big 'D' Posted November 20, 2009 Posted November 20, 2009 What time are you getting together round there, Ill pop across for one of your famous brews! I will get back to you on that nothing is set yet Cheers Iain
myles Posted November 21, 2009 Posted November 21, 2009 Ha ha, we will block off your street and terrorise the neighbours!
Big 'D' Posted November 21, 2009 Posted November 21, 2009 Ha ha, we will block off your street and terrorise the neighbours! Hey Myles I can Romanian deadlift 150kgs now Cheers Iain
stum450n Posted November 21, 2009 Posted November 21, 2009 Hey Myles I can Romanian deadlift 150kgs now Cheers Iain my god mate, just realised that's nearly two of me and I'm not exactly known for my slimline appearance!
myles Posted November 21, 2009 Posted November 21, 2009 Hey Myles I can Romanian deadlift 150kgs now Cheers Iain Good lad. I have tennis elbow and havent done any weights for about a month. I also has swine flu at Cosford and have not done any cardio apart from one trip to the treadmill in the same period. Romanian(straight legged) or normal?
Big 'D' Posted November 21, 2009 Posted November 21, 2009 Good lad. I have tennis elbow and havent done any weights for about a month. I also has swine flu at Cosford and have not done any cardio apart from one trip to the treadmill in the same period. Romanian(straight legged) or normal? Straight legs mate, x2 Stus thats massive Cheers Iain
stum450n Posted November 21, 2009 Posted November 21, 2009 Straight legs mate, x2 Stus thats massive Cheers Iain :D
edmondo Posted November 21, 2009 Posted November 21, 2009 lol not you too ED only kidding mate...............Car M.O.T Tuesday so darent use it...................however my few remaining faults might need looking at
Big 'D' Posted November 21, 2009 Posted November 21, 2009 only kidding mate...............Car M.O.T Tuesday so darent use it...................however my few remaining faults might need looking at What else needs looking at ED? Cheers Iain
edmondo Posted November 21, 2009 Posted November 21, 2009 This has been communicated to you ..............what time is James04 ( Dean ) due up to you?
myles Posted November 21, 2009 Posted November 21, 2009 Straight legs mate, x2 Stus thats massive Cheers Iain Good skills, just keep an eye on that back. What about real mens deads?
Big 'D' Posted November 22, 2009 Posted November 22, 2009 Hi Iain, are you still up for me coming around about 3pm 'ish. I sent a text but not sure if you got it or not?Cheers, Colin If you could leave it a little later in the day that would be cool mate as we have a couple of mates round for Sunday dinner. Cheers Iain
