lumsden26 Posted October 23, 2009 Posted October 23, 2009 (edited) hi there i just bought a centre de cat for my00 classic uk turbo 2000 and on recieving the pipe i thought look'd different from my last de cat, on reading the ad again the guy bought it for his 1996 wrx import will this still fit? one of the end flanges looks wrong and is it the same length??? if not anyone wanna buy it? Edited October 23, 2009 by lumsden26
euan_r Posted October 24, 2009 Posted October 24, 2009 should fit if your current exhaust is indeed standard and new pipe is indeed of another classic and 2.5". its only four bolts and exhaust hanger anyway.
kogii Posted October 24, 2009 Posted October 24, 2009 hi there i just bought a centre de cat for my00 classic uk turbo 2000 and on recieving the pipe i thought look'd different from my last de cat, on reading the ad again the guy bought it for his 1996 wrx import will this still fit? one of the end flanges looks wrong and is it the same length??? if not anyone wanna buy it? import may have diffrent length.. but i'm not sure
superstar_tradesman Posted October 24, 2009 Posted October 24, 2009 import may have diffrent length.. but i'm not sure IIRC the import downpipe is different to the UK spec one.
gus the bus Posted October 25, 2009 Posted October 25, 2009 Deffo the same! no difference between the two. Unless he has hacksawed the pipe As Euan R says the only difference could be the diameter (ie is it 3") even with that you can still make it fit. Gus
superstar_tradesman Posted October 25, 2009 Posted October 25, 2009 Deffo the same! no difference between the two. Unless he has hacksawed the pipe As Euan R says the only difference could be the diameter (ie is it 3") even with that you can still make it fit. Gus Are they not longer and wider gus?
gus the bus Posted October 25, 2009 Posted October 25, 2009 Are they not longer and wider gus? Nope, same same. Newage V Classic are different lengths (due to cat pipe) but classic regardless of Import or UK are the same length/dimensions if a standard system is fitted.
lumsden26 Posted October 25, 2009 Author Posted October 25, 2009 its standard exhaust and new pipe is 2.5''. So take it this is ok and should fit? Cheers mark.
