Stick With Same Oil Or Change Spec?
I'm just about to do a service on my 52 reg STi type uk and thought I'd check what the general concensus is.
The car has just turned 80k miles and has been using 5w/40 Shell Helix Ultra (Fully Synthetic) for all of its life so far.
Just thought that with the engine getting on in miles would I need to change the oil grade, or should I even be looking to change to a better make/spec of oil for this and future services?
Cheers,
Phil
Cheers,
Phil
been using fully synthetic 5w40 in ma classic for over 2 years now and av passed the 100k mark and engine as sweet as a nut still
Cheers b4z,
As this has used fully synthetic oil all it's life I know that's what I'll stick with, but it was just more a question of whether you need to use a different grade of oil as your motor gets older or not?
Also if there are recommendations for using a different brand or just keep using the same to aid the longevity of the engine? :thumbup:
Shell Helix is not a true fully synthetic oil.
Try using
http://www.millersoils.net/1_Millers_frame_MOTORSPORT.htm
depending on budget and car usage
http://www.motul-oil.co.uk/pdfs/300v-engin...40_TDS_(GB).pdf
http://www.motul-oil.co.uk/products-300v-engine-oil.php
I get mine from Alyn at AS Performance. The motul is prob overkill for a road car though.
Funny you should say that Arch, I've just been researching for the last 1/2 hr to find that although the Shell Helix is sold as Synthetic, it is merely a Hydrocracked Petroleum based oil from refined mineral oil :rotfl: .
Is it ok for me to change from using a Type 3 oil to a Type 4/5 (Millers/Motul), or will I need to flush it out first?
I'll look at the Millers I think :thumbup: .
How'd you get on this weekend anyway?
Edited by Phil MC
