dipsy Posted August 28, 2009 Share Posted August 28, 2009 Is it allright to use Castrol syntrax for service of new age 6 speed gearbox with A- DCCD and use it in the rear diff will it work with lsd if it has one .Going to halfords to get engine oil which i know what i won't and buy this gear oil if its right for doing the hole lot of as above i mentioned if you can help me out please Link to comment
jimser Posted August 30, 2009 Share Posted August 30, 2009 Is it allright to use Castrol syntrax for service of new age 6 speed gearbox with A- DCCD and use it in the rear diff will it work with lsd if it has one .Going to halfords to get engine oil which i know what i won't and buy this gear oil if its right for doing the hole lot of as above i mentioned if you can help me out please i used syntrax in both g/box and rear diff in the spec c. there is probably something better out there but at the time i needed oil quick and halfords was local Link to comment
dipsy Posted August 30, 2009 Author Share Posted August 30, 2009 Thanks for the reply Jim . Link to comment
dipsy Posted September 2, 2009 Author Share Posted September 2, 2009 http://www.racelubricants.co.uk/product.as...08&P_ID=439 .Here's a link to get castrol snytrax at a cheaper price if you use it Link to comment
