ally-b Posted July 29, 2009 Share Posted July 29, 2009 My mate asked for PC help , but in this case I'm stumped . Does anyone know a fix for this ? It seems to be a fake antivirus site , but is actually a virus itself . PAV or Personal Antivirus is its name . His OS is Vista. Any help appreciated , ta, Al Link to comment
pmacFTO Posted July 30, 2009 Share Posted July 30, 2009 (edited) I've dealt with this one a few times and it can be easy or bloody hard! The worst version actually survived a HD format numerous times but the majority of infections can be sorted with a few scans and a bit of registry editing. I do this all the time as a PC Repair man For a start turn off System Restore (check help on how to do it)! Empty the files inside C:/Windows/Prefetch. Do Windows Update (if you can get to the website as this virus redirects your browser sometimes). Get Spybot, Malwarebytes and HiJackThis - get a good Anti Virus (Avira, NOD32) and boot to safe mode (important!) and run them all and clean whatever they find - run them a few times too. HiJackThis is just a tool to report but the log can tell you a lot - post up the log and I can tell you what to disable after. If you need to, download all the apps mentioned and stick them on a memory stick and then install them with the PC disconnected from the web. Before you do all that you could try to do an online scan - you may or may not be able to depending on what the virus has done. http://www.eset.com/onlinescan/ that's the NOD32 online scanner http://www.f-secure.com/en_EMEA/security/s...online-scanner/ That is the F-Prot online scanner (You will need to run these in IE - they don't work in Firefox) Edited July 30, 2009 by pmacFTO Link to comment
mikeb36 Posted July 31, 2009 Share Posted July 31, 2009 It's a rogue program. I know that MalwareBytes anti-malware removes this parasite. And it could be removed manually, but I think this is very complicated method, because you have to remove those registry entries and other files. You can also use Spyware Doctor to remove Personal antivirus. Link to comment
ally-b Posted August 1, 2009 Author Share Posted August 1, 2009 Thanks guys . I'll try those ideas later today . Al. Link to comment
