billyboystoys Posted May 16, 2009 Posted May 16, 2009 there is a whine started to come from back wheel at least i think it is the back wheel not there all the time like last night drove back home 5 mls turned into my drive way and it was whining kind of on and off reversed then drove forward and it disapeared ? anyone had this before , billy.
braveheart Posted May 16, 2009 Posted May 16, 2009 Hi Billy, I had a whine not so long ago from my rear left, again only heard it now and again, when i was turning, on inspection it was my wheel bearing on the way out, hope this helps. Chris
StewartyBoy Posted May 16, 2009 Posted May 16, 2009 Definately wheel bearings. Aint expensive to fix.
Jazmac Posted May 16, 2009 Posted May 16, 2009 could be something very simole like a stone inbetween the disk and heat sheild, when you reverse it normally shifts it, and bingo no more whine. hope thats all it is for you
Midnight21 Posted May 16, 2009 Posted May 16, 2009 could be something very simole like a stone inbetween the disk and heat sheild, when you reverse it normally shifts it, and bingo no more whine.hope thats all it is for you I had that whine noise on mine too and it turned out to be a stone jammed in between the heat shield and disc! whine wasn't there when i reversed then the noise disappeared
thewelsho Posted May 16, 2009 Posted May 16, 2009 there is a whine started to come from back wheel at least i think it is the back wheel not there all the time like last night drove back home 5 mls turned into my drive way and it was whining kind of on and off reversed then drove forward and it disapeared ? anyone had this before , billy. Wouldn't be the handbrake not properly disengaging, would it? Jack your car up and check to see if there is any lateral play in the wheel. Usually a wheel bearing is a drone and not a whine.
billyboystoys Posted May 16, 2009 Author Posted May 16, 2009 cheers guys will give all these things a check billy
jasonb Posted May 17, 2009 Posted May 17, 2009 I had same problem and it was the brake shoes inside the drum for the handbrake!!!
billyboystoys Posted May 18, 2009 Author Posted May 18, 2009 I had same problem and it was the brake shoes inside the drum for the handbrake!!! i think i will strip the brakes down got a new set off discs to go on anyway so hope to get this sorted cause its doing my box in cheers jason
