Rocker Gasket Kit's
Well after disappearing for a while, it has started smoking again so going to tackle this.
Theres no Subaru dealer nearby so where is best to buy the parts?
So far I have seen them available at...
Flat 4 Online - Are these genuine OEM parts? Also it says suitable for 1992-1996, Mines is a 1997 V4 sti type r import, will this be the right one?
http://www.flat4online.co.uk/catalog/produ...r-cover-gaskets
Graham Goode - Havent a clue what ones I need! Again are these OEM parts? If not better or worse?
I think the part numbers I need are :
GGS866 : Spark plug gasket EJ20G engine (x2)
GGS867 : RH rocker cover gasket EJ20G - 9/96 (x1) - Again only mentions up till 1996
GGS1026 : Rocker Cover Bolt Seal (x6)
GGS608 : Half moon seal for rocker cover (x2)
GGS662 : 3 bond grey gasket sealer for sump (x1)
http://www.grahamgoode.com/subaru/parts.php?group=66
Edited by hacky
Why not just to your local scooby dealer who will get them for you? Eaglesham will be able to get them for you even if you have an import.
Ricey
Yup, they supplied me them no problem. Shame it was the wrong ones, twice.
Ended up going to lateral perfomance. Right parts first time and mail order too.
Couldnt get through to Lateral, however called up RCM and they were really helpful and sorted me out. As mines is June 1997 it could have been one of two rocker gaskets so they are sending me both and I just return the other one, save any confusion! Should be with me for the weekend so I can set about it. Its a bit embarrassing pulling into work with smoke coming out the bonnet vent!
Cheers guys.
Going to attempt this tonight, i'm assuming that I will need to dump the oil first? Take it there would be some oil still sitting in the head?
^^^^^^^ Thats a top tip from Dave.
Put aside the whole night for it, take everything you can out of the way (washer bottle, battery, airbox etc). It'll come apart easy enough but spend some time geting the faces CLEAN. Oh and don't overtighten the bo;ts when putting the covers back on, they've been known to snap..
Best of luck.
Cheers guys,
Its just the drivers side, as usual, got to the point where its doing my tits in.
Just need to make sure I don't break anything in the process like I normally do! Also heard about danger of breaking the coil packs. Plan on just swinging them round out the way.
And I've heard about over tightening them, don't fancy snapping a bolt!
Just to give you an update.
Managed to get the job without any major problems! Thank god!
It was a ******* to get the actual rocker cover out. I managed to get the 6 bolts off fine, but actually pulling it up was a mission.
Anyway, problem now sorted and I have a nearly full tube of three bond left over, wish I had bought a smaller tube! lol Expensive stuff too, think I've got a lifetime supply of it!
Cheers for the help guys.
