Induction Kit, Which Is Best?
  Big Gordon said:
Looking into getting one fitted to my MY03WRX and just wandered if you guys could recommend any and what kind of price i'm looking at?
Wouldnt recommend any cone filter induction kits to be honest unless you are running a front mount, only because youd need to for space.
induction kits dont work as well as the original airbox with a good panel filter fitted.
Induction kits usually pull so much hot air in from the engine bay that they hamper performance rather than gain any. The claims of HP increases are normally invalid TBH.
If you do want one, id stick with the ENCLOSED TYPE feed kits, but then yorue paying £200 for a system thats just as good as your airbox and a £50 panel filter!!!
You can run over 350/350 on standard induction with just a decent panel filter Gordon. I went through the whole dilema of what to fit to mine when I did my power upgrades and all the advice was not to bother.
I'm running 290/290 on a 05 WRX with standard induction and turbo. So it's clearly up to the job!
As above, STI panel filter until you go fmic and have to change.
If you really must the apexi power intake is the best one out there. Good filtration and dry so it's relatively maf friendly.
