cossie_eater Posted June 14, 2008 Share Posted June 14, 2008 ive got a 2004 wrx lowered with tein springs, and running 225-40-18 tyres. and it rubs like mad, every bump in the road. should i : go 215-40-18 or 215-35-18 or go back to 17" dont really want this path as i got 356mm calipers to go on all advice welcome cheers Link to comment
bmwhere? Posted June 14, 2008 Share Posted June 14, 2008 If you go to 215/40 or 215/35 on 18" then you'll probably need to get your geometry reset and and the speedo re-calibrated. 17" won't really give you anything other than a softer ride if you keep the original profile tyres it'll still rub and if you go for a lower profile, then you still have the geometry/speedo issue! Link to comment
ace555 Posted June 16, 2008 Share Posted June 16, 2008 It sounds more like an offset issue. What wheels have you got on her? Link to comment
