stubaroo Posted May 19, 2008 Posted May 19, 2008 Another newbie question. I am about to get a 30,000 mile service carried out on my 2004 WRX. Part of this service is the replacement of the - "spark plugs and filters". (This is not a reference to oil, air or fuel filters). What are spark plug filters? I also see after a small search that some Impreza's don't have HT leads but have individual coil packs, is that right? Whats the set up on a 2004 WRX? Thanks for any enlightenment forthcoming.
colin_ross Posted May 19, 2008 Posted May 19, 2008 Never heard of spark plug filters. I'm no newage expert but believe that the 04 has coil packs. These are not service items and would only be replace if faulty. Could it be a pollen filter they are referring to?
stubaroo Posted May 19, 2008 Author Posted May 19, 2008 (edited) Never heard of spark plug filters.I'm no newage expert but believe that the 04 has coil packs. These are not service items and would only be replace if faulty. Could it be a pollen filter they are referring to? Looks like its relevant to the spark plugs. The following is an extract from the sevice manual. The line in question is highlighted. 2004 Subaru Impreza WRX 2.0 litre Turbo 30,000 mile service Drive belts (except camshaft) - Inspect Engine oil (ACEA B3 Only) - Replace Engine oil filter - Replace Engine coolant - Inspect Cooling system, hoses and connections - Inspect Fuel filter - Replace Air filter - Replace 4 Gas analysis/select monitor check - Inspect Spark plugs and filters - Replace Clutch operation - Inspect Valve clearance (adjust at additional cost) Transmission oil (filter automatic) Diff oil (front/rear) - Replace Brake and clutch fluid - Inspect Lubrication of bonnet and door catches - Inspect Fuel system lines and connections - Inspect Disc brake pads/Discs - Inspect Brake linings and drums - Inspect Brake lines - Inspect Park and service brake operation - Inspect Front and rear axle shafts and joints - Inspect Steering and suspension system - Inspect Operation of lights, wipers and washers - Inspect Tyre condition and pressures - Inspect Edited May 19, 2008 by Stubaroo
stubaroo Posted May 19, 2008 Author Posted May 19, 2008 (edited) Any more opinions, welcomed. Surely one of our more knowledgeable/mechanically minded members can shed some light on this one. Spark plugs and filters!! HT leads or coil packs? Edited May 19, 2008 by Stubaroo
RS Grant Posted May 20, 2008 Posted May 20, 2008 To be honest mate, I'm not the most technically/mechanically minded person but I've never heard of a filter being mentioned in conjunction with Spark Plugs... I was also think it was an Air Filter, Pollen Filter or Oil Filter that they are talking about, however, the extract you show kinda blows that out the water!! Could always phone Subaru UK Customer Service and get them to clear it up I suppose. Cheers, Grant
