Help Please!
http://forums.sidc.co.uk/index.php?showtopic=111781&hl=
Nobody seems to have looked let alone answer so I thought I'd point my Scottish brethren in the direction of my post :o
Paul, last post before I head for the Airport!
tbh I think your BIGGEST problem with the car is running 19's. 18's can be bad enough for torque steer problems 19's with VERY low profile tyres would cause much of your problems IMHO.
Best thing to do would be get a lone of some standard 17's for a few days and see if there is a difference. I think you will notice it right away :)
Over and out! ;)
Best thing to do would be get a lone of some standard 17's for a few days and see if there is a difference. I think you will notice it right away :banana:
Over and out! :P
I'll lend you some 17 if you like. Tyres are not great but they will do you a turn to at least try them out. I have a track day on March 15th so if you want to try the 17s ma man, you can, just as long as I get them back a couple of days before the 15th. You might also want to try a change to your geometry. In standard trim the Scoob is set up to understeer. The reason for this is that it is easy to correct by simply lifting off. However, oversteer is not so easy. It's a kind of fail-safe measure to protect new Scoob drivers from thinking they are invincible behind the wheel of their new car, so I have been told.
Over and out! :P
i will second this,
im running 18s with a rubber band profile, very different car from wen i had the standard 16s on, so much so im thinking of downsizing soon
craigy
