Changing Fuel Pump
Ma fuel pump is boke so just got a new walbro one. I have a late 97 classic turbo2000. A had a look in the scoobypedia about changing it and in there it says take back seat out undo the five bolts holding on the plate and bobs your uncle its under there. Was wandering if thats for the newer models because av got ma seat out and cannot find any access to the pump can anyone help.
I cant see anything under the seat that is removable only 2 rubber gromits 1 is round cables and the other looks like its round brake pipes.
You've removed the seat base which is held in place by 2 bolts.
Remove the seat back ( 3 bolts) and lift the seat back up off the retaining clips.
You'll then see an oblong cover on the drivers side with 4 screws. (You can see the cover from the boot area if you lift the boot carpet. There's also a round cover on the passenger side, but you're not interested in that). Remove the plate, then remove the electrical connection and the hose pipes there, being careful removing the hoses (gently) cause there will probably still be fuel pressure in them.
Remove the 8mm nuts (socket size) off the top of the plate and the whole assembly including pump will come out
Edited by AlanG
follow the things that look like brake pipes, should be the fuel lines as brake lines run under the car i think
As Alan says buddy not a hard job just a bit fiddly
Gordy
When i did this a few months ago i had to strip out the boot and remove the rear seats. Made it a lot more simple.
Hard part for me was getting the rubber pipes off the connections on the plate the pump is mounted on. ;) Bad language helped.
Willie
