Can Anyone Lend Me A Cat'd Centre Section For Classic
MOT failed:Can anyone in the Central Belt lend me/hire me a CENTRE SECTION WITH A CAT ON for a classic 2.5" diameter.
Appears the pipe that I took off to stick a Gus the Bus special on isn't cat'd after all :o
cheers ,in desperation ,Col :thumbup:
i wouldnt chance an mot on only the center cat. i think there was a double center doing the rounds up here for that purpose. hope u get a lend locally.
That anygood to you? ill messure it etc if your wanting it
paisley area
chris
thought your car was a pre95/96 car ..iff its is you should not be getting a cat test just the emmisions test
Aye its a '94 so technically don't need a cat but the emissions were through the roof,is there another way off getting emissions down(a lot in this case)
is that two cats Chris?
not sure if its silencers or cats bud, it came off the car when I got the decat centre sec.
wire in to it if you want
You couldni shine a torch doon it could you,if they are like the pics above then its just wee silencers.
cheers,Colin
P1's only came with one cat and they pass ok. I don't see why any other classic should be different.
defo 2 small silencers, basically a straight thro pipe, just to dull down the noise
ah right, didnt know that! I might well put this back on then! When I got the car the only upgrade on it was a tannabe exhuast. I thought it was just a backbox! So this must be part of it
theres me taking it off and buying a straight though thing for 100quid! when I had less noisy one.
too the sell section! :thumbup:
no prob cjk
chris
that will be the bigger one in downpipe i imagine, not owning one.
dont have anything Gordy,going for thr easy option with the centre section.
The linky isni working Chris...whats the item number
