Anti Lock Brake Light On
you can self read abs codes. it changes with year but the black connector on steering column that is spare when doing an ecu code check you ground one of the pins and abs light flashes code. others have different abs diagnostic connector. help identify which sensor is wrong/cleaning etc.
ps. check brake lights
Edited by euan_r
the light went out again strange not to worry all is good
Mine comes on if i'm 100+ on a bit of a bumpy (Private) motorway... ignition off then back on and weeeeeeeee I've got abs again.... Really should get that seen to lol ;)
Mine started coming on due to a wheel bearing issue. Would come on round specific corners (most noticeably the cambered one on the m8 outside the Bar-L). Once the wheel bearing was fixed i was good as new.
