seafar99 Posted December 8, 2007 Share Posted December 8, 2007 Can't work out what's up with my PC. When i try to watch video clips on youtube etc i get a message relating to "Your JavaScript may be turned off" . I don't remember turning the bl**dy thing thing off in the first place....so PC boffins How do i turn it back on? Craig(The Technology Turnip) Link to comment
andy Posted December 8, 2007 Share Posted December 8, 2007 First step is to make sure your version of Java is up to date as it may not be turned off at all. Download and install the correct up-to-date client for your browser: Clicky Link Link to comment
seafar99 Posted December 8, 2007 Author Share Posted December 8, 2007 First step is to make sure your version of Java is up to date as it may not be turned off at all. Download and install the correct up-to-date client for your browser:Clicky Link Verified Java Version Congratulations! You have the recommended Java installed (Version 6 Update 3). ..............yip all up to date, but still getting the"may be switched off" message. how do you turn it on?. Link to comment
seafar99 Posted December 8, 2007 Author Share Posted December 8, 2007 Sorted, thanks Andy. Link to comment
seafar99 Posted December 8, 2007 Author Share Posted December 8, 2007 Some video clips seem to be working and some flash up "Java Script seems to be turned off. Link to comment
nanaki Posted December 8, 2007 Share Posted December 8, 2007 are you using firefox with the noscript plug in as it wont allow java scripts to run till you give the website permission (temp or permanent) Link to comment
