paulc555 Posted October 28, 2007 Posted October 28, 2007 Hi all As you know been working on the track car all week.....and made sure to start it and let it run a few minutes each day.....just to keep it ticking over as it isnt being driven just now... However ...went out this afternoon to finish priming the floor pan and it wont start.... HELP........its turning over okay, but just wont catch....battery fine...fuel fine....anyone any ideas or willing to come and look at it for me....expenses paid...no problem.............not in a mad rush but would like it looked at by next weekend if possible.... anyone able to offer mechanical assistance... PLEASE................. Paul
RA Dunk Posted October 28, 2007 Posted October 28, 2007 can you hear the fuel pump priming before you try to start it?
paulc555 Posted October 28, 2007 Author Posted October 28, 2007 can you hear the fuel pump priming before you try to start it? yes the car is fully stripped so there is a lot of noises....but Im sure I can hear the fuel pump... Fraz thinks it could be the spark plugs as I havent been driving the car just starting it for a few minutes at a time....? dont fancy changing those..!!
STi_Bandit Posted October 28, 2007 Posted October 28, 2007 i had a simalar problem on my old car that it would turn but not catch, turned out to be the Crank Position Sensor, dont know if this could be the problem but a suggestion. Bandit
paulc555 Posted October 28, 2007 Author Posted October 28, 2007 i had a simalar problem on my old car that it would turn but not catch, turned out to be the Crank Position Sensor, dont know if this could be the problem but a suggestion.Bandit thanks Martin....will add it to the list of possibles..
paulc555 Posted October 28, 2007 Author Posted October 28, 2007 thanks Martin....will add it to the list of possibles.. did this happen suddenly Martin...its just the car started fine with no indication of any problems yesterday...
STi_Bandit Posted October 28, 2007 Posted October 28, 2007 did this happen suddenly Martin...its just the car started fine with no indication of any problems yesterday... It did just suddleny happen, went out one morning tried to fire her up and all she did was turn but never catch and the AA man diagnoised it as a dirty crank poistion sensor which he cleaned and that sorted it. Iam not saying that what youve got but could be an idea. Iam sure there are people here alot more mechanically minded than me. Bandito
cusco kid Posted October 28, 2007 Posted October 28, 2007 Hi allAs you know been working on the track car all week.....and made sure to start it and let it run a few minutes each day.....just to keep it ticking over as it isnt being driven just now... However ...went out this afternoon to finish priming the floor pan and it wont start.... HELP........its turning over okay, but just wont catch....battery fine...fuel fine....anyone any ideas or willing to come and look at it for me....expenses paid...no problem.............not in a mad rush but would like it looked at by next weekend if possible.... anyone able to offer mechanical assistance... PLEASE................. Paul paul listen for fuel pump it shpuld prime up for 2-3 secs switch off ign then switch on again you should hear the buz or whir for again 2-3 secs if thats ok then take the main fuel feed at fuel rail from filter and place into a bottle get somewone to crank engine for 5 sec max if there is plenty high preasure its ok .now remove the plugs its easy--remove washer btl to gain access at the pass side rem/ full airfilter other side that will let you in at that side if you have seperate coil packs you will need a 12mm spanner to remove them you cant go wrong refitting them as they are a dedicated length on the wiring its a good time to check for firing at the coil packs place an old s/plug in the end and crank holding the s/p against the engine look for a fat spark if thats ok after cleaning the plugs you will have to go deeper watch for soilled fuel m8 geo
paulc555 Posted October 28, 2007 Author Posted October 28, 2007 paul listen for fuel pump it shpuld prime up for 2-3 secs switch off ign then switch on again you should hear the buz or whir for again 2-3 secs if thats ok then take the main fuel feed at fuel rail from filter and place into a bottle get somewone to crank engine for 5 sec max if there is plenty high preasure its ok .now remove the plugs its easy--remove washer btl to gain access at the pass side rem/ full airfilter other side that will let you in at that side if you have seperate coil packs you will need a 12mm spanner to remove them you cant go wrong refitting them as they are a dedicated length on the wiring its a good time to check for firing at the coil packs place an old s/plug in the end and crank holding the s/p against the engine look for a fat spark if thats ok after cleaning the plugs you will have to go deeper watch for soilled fuel m8 geo thanks George.....will read this another 20 times to make sure I understand it first....cheers Paul
paulc555 Posted October 28, 2007 Author Posted October 28, 2007 Fouled plugs a good possibility Plugs so far seem to be the number one culprit....any special tools needed guys or just my trusty socket set...that santa got me thats only been opened once.... apart of course from the one thing i dont have which is patience..... suppose now would be a good time to learn with the project i have taken on...
jamie_wood Posted October 28, 2007 Posted October 28, 2007 Sorted now I hope. Dont be shy in calling me staright away the next time matey. Saves you going off in the wrong direction
jamie_wood Posted October 28, 2007 Posted October 28, 2007 P.s, you will know when it "dies" properly as pistons and rods normaly pop out the top of the block, followed by a small fire
nippysweeties Posted October 28, 2007 Posted October 28, 2007 Sorted now I hope. Dont be shy in calling me staright away the next time matey. Saves you going off in the wrong direction Spill the beans then! Steve.
jamie_wood Posted October 28, 2007 Posted October 28, 2007 Pumps were out of sync and the Anti lag was also over fueling. That and the nut that holds the steering wheel.
paulc555 Posted October 28, 2007 Author Posted October 28, 2007 Pumps were out of sync and the Anti lag was also over fueling.That and the nut that holds the steering wheel. aye your right mate....... I'll be completely bonkers by the time I get the plugs out.. cheers for the advice mate...just be on standby for a free dinner next sat...
jamie_wood Posted October 29, 2007 Posted October 29, 2007 You will have it done in half an hour P.s give me a shout tonight if you have time. There is something else you will need to do before you can take it on the road. Remember to call the right number this time. I will be at the country house, not the city pad
