Temperature Help
on the way home today my wife noticed that the gauge went into high.
i then checked the water and put 1 and half kettles full of water in.
Then went to a meet today and it was fine on the way but on the way back the temp one min was high and then it would go back to normal!!
cant see any water leaks....
any ideas????????????it also seems to have a flat spot at different times!!
hope someone can help
You could try the cheaper bits first.
Maybe a sticky thermostat, or the old enemy, air-locks
sounded like a possible air lock but how can i rectifie this??
no water in the oil is there.............no white around the oil filler cap,could be the head gasket...i hope not..
no thank god cant see any......1st thing i checked...just puzzled that it was up and down and not constant?????
I haven't tried on a scoob before, and from what I hear they are a ba$tard, but there should be bleed valves dotted around the system. Usually at the top of the rad, somewhere near the thermostat, and in the region of the pipes that go to the heater matrix. Just get the engine running and warmed up, and crack them off GENTLY.
[PING] An idea has occurred. Your footwells aren't damp are they? Sometimes after a summer of being shut off, the heater matrix can rot out causing airleaks and lost coolant.
not sure will have to chect this in the morning
maybe just run short of water for a while,you filled it up,then drove it for a bit and it has caused a slight airlock, maybe ok tommo,check the levels in the morning..hope donkeys right..
cheers all
put some more water in this morning with engine idling and squeezing top hose to get any air out and it now seems fine for now B)
Hope everything is allright with your car today Rand, Found any leaks, anti-freeze marks, or wet patches?
Monki.
