philrsi Posted October 16, 2007 Posted October 16, 2007 The time has come for me to do an oil change on the old girl. So apart from the oil and a filter, what else do I require? Are there any special tools needed to get the sump plug out, can I get new sump plug washers from any old motor factors? Cheers
Dalthegooner Posted October 18, 2007 Posted October 18, 2007 No special tools needed for the oil change. Check out Scoobyparts.com. You get a sump plug washer with the oil filter.
rasher Posted October 18, 2007 Posted October 18, 2007 ^_^ just ensure you fill the new filter with oil before you connect it up
paul n Posted October 22, 2007 Posted October 22, 2007 Also, pull the fuel pump fuse, so car won't start till oil pressure there, 2 or 3, 20 second cranks with a full oil filter will sort it
blue boy Posted November 30, 2007 Posted November 30, 2007 Are you going to join us on a CADS Meet Phil?
