Knocklink And Afr Device Help.
Typlical Applications:
1. Analyze fuel maps
2. Intermediate engine health monitoring
3. 5 Fully customizable gauges
4. 90 Minutes data logging
5. Stand alone engine management system interface
6. Piggyback fuel system interface
7. Interface with data loggers
8. Stock narrowband sensor replacement
Key Features:
* Measures Wideband Air/Fuel Ratio
* Integrated 6 Inputs for data logging (2 Speed, 3 Analog, 1 AFR) - Log virtually anything including RPM.
* 90 minutes of onboard memory for recording and PC download
* Analog outputs for 3rd party interface
* Replace your stock narrowband sensor.
* Fully customizable LED warning light or shift light
* High speed USB 2.0 interface
* Powerful 32 bit integrated processor, RAM, and FLASH technologies
* 100% backwards compatible with M-Series controllers
* Compact dash mountable design (4.75 x 2.25 x 1 inch)
* Sensor soft start circuitry, prolongs o2 sensor life
* Powerful PC analysis software included (PLX Logger Version 2.1+ Free Download)
* Field firmware upgradeable (more features added to R-300 regularly)
Included:
1. R-300 dash mountable compact wideband controller
2. Bosch LSU 4.2 Wideband O2 Sensor
3. 3ft Bosch O2 Sensor Harness (Controller side)
4. 8ft Bosch O2 Sensor Harness (O2 sensor side)
5. 3ft Main Harness (controller side)
6. 4ft Main Harness (user side)
7. 4ft Main Harness Power Wires (user side)
8. USB interface cable (R-300 -> PC connectivity)
9. PLX parallel port firmware reflash card
10. Comprehensive operating manual
11. CD with USB device driver, operating manual in PDF, Latest version of PLX Logger Ver2.1+ (Win95/98/NT/2000/ME/XP) Compatible.
The R-300 is a compact, dash mountable, easy to use wideband air/fuel controller with powerful data logging capabilities. Wideband air/fuel ratio can be monitored in numeric, gauge or graphical form. Data logger inputs can be fully customized to display virtually ANY type of data. It's like combining 6 gauges into one! The R-300 can store up to 90 minutes of logged data and 99 individual sessions for later PC download and analysis with PLX Logger PC software.
cant beleive how quick i managed to type all that. :o
Is this like a "James Bond" gadget or does is it really useful? Would that help pinpoint the reason for my misfire???? Much you selling that for?
probably wouldnt diagnose your misfire probs john unfortunately but does have it uses.
wideband sensor for afr plus can monitor things like throttle position,map mass air flow sensor,air intake temp,engine coolant temp,exhaust gas temp,vehicle speed(mph/kph),ignition pulse(rpm),shaft speed sensors.
though is limited to only 6 of the above
Be good if I know whathalf of that meant! :o
