Spark Plugs
The picture below shows the spark plug from my car: MY06 WRX 2.5. the brand new one was bought to slot in to a MY05 STi 2.0. As you can see, there is a considerable difference in size of them, so take note if you are going to change your own plugs, that plugs from older models will not do.
Edited by TheWelsho
SUBARU 2.0 IMPREZA (10/00-->) SPARK PLUGS
Showing Recommended Products. Click on "Extra Info" to view full details for that product.
Model Detail Engine Type / Additional Info Year Part No Stock No Extra Info
IMPREZA (10/00-->) 2.0 EJ20 / 19mm Reach Plugs 10/00 –> PFR6B 3500 Extra Info
IMPREZA (10/00-->) 2.0 EJ20 / WRX STI 19mm Reach Plugs 01/02 –> PFR6B 3500 Extra Info
IMPREZA (10/00-->) 2.0 EJ20 / 26.5mm Reach Plugs 09/05 –> ILFR6B 6481 Extra Info
SUBARU 2.5 IMPREZA (10/00-->) SPARK PLUGS
IMPREZA (10/00-->) 2.5 EJ25 / 26.5mm Reach Plugs 01/06 –> ILFR6B 6481 Extra Info
so the part number that you should be looking for is ILFR7B if they do one
where did you find that Peter? the number on my current plugs is ILFR6B. Itake it the 7s are the performance ones.
Correctamundo!
Russell
The 7 is a 'colder' plug - dissipates heat into the head/water jacket faster and helps to reduce combustion chamber temps so fending off the possibility of detonation. Good idea to fit colder plugs when remapping for increased boost and performance.
However, somewhat bizarrely, NGK don't make an ILFR7B plug! (sorry - dont' know why there isn't a straight heat rating number change like there was on the PFR plugs used in 2.0 engines)
Correct part no. for colder plugs on the 2.5 is ILFR7H ;) (same plug used in the Evo IX).
Hope this helps.
Cheers,
Stewart.
Hope this helps.
Cheers,
Stewart.
YES! Got those, fitted them. Now PLEASE go look at my other thread and see if you can help me Stewart as plugs didn't work!
Edited by TheWelsho
