Achtung! Please Read
Now that things have settled down after the migration, there's one little thing still remaining that requires some action from each of you. I'm going to sort this on a regional forum-by-forum basis starting with my fellow Jocks.
With the new membership management system you have a membership control panel you can access to check membership details, renew etc. Most of you don't have access to that right now as I have to manually sync your Forum account to your membership account before it will work properly.
If I have already told you how to renew online and you have had access to the membership control panel then you can ignore this as the work is already done.
However, if I haven't told you and you are a current SIDC Member, or even if you are an ex-member who has lapsed, please log a support ticket by clicking here. All I need is your real name, your forum user name, your current email address and if you are a member, your membership number. In the box where it asks you to describe the problem, just put something like "Membership control panel access"
If you do that, I'll do the sync between your forum account and your membership control panel and you'll then be able to login to it at any time and check membership status and renew etc. It's just a one-off thing, but is pretty much the final piece of the jigsaw. :icon_salut:
Thanks folks :D
I'm going to add a bit onto the member control panel that will display your membership number as I've found folk have a tendancy to forget it and / or can't be a***d walking to the car to find out ;)
