Speed Limited
hi folks, i was wondering where i can get the speed limiter taken off my '94 import and if any one knows how much power these one should have as standard? cheers :occasion14:
what is it?
see if u have reed switch in the back of speedo, if u do u can solder on a by pass. if you have a mechanical speedo you could also fit reducer gear on speedo cable which converts kph to mph and as a result moves cut off point somewhere above 150mph. third option would be to wire in hks sld if you have electronic speedo.
hi folks, i was wondering where i can get the speed limiter taken off my '94 import and if any one knows how much power these one should have as standard? cheers :lol:
Fit a scoobyecu (chip) removes the 114mph limit :P and gives you a good few extra ponies (if fitted with a decat, uprated fuel pump and CAI)
Edited by Gus the Bus
