sensor in down pipe!!!! not lambda!!
ok folks i was wondering wat the small sensor at bottom end of down pipe is, i know its not the lambda as thats in my headers!! anybody got any ideas????
Exhaust Gas Temp
It tells the ECU that your Cat is on fire
ok cheers squirrel but is it a must to have it as its lying on my garage floor beside the cat!!!!! and its not on fire
On a std ECU i prefer them connected but on a mapped ECU it can be disconnected
On Fitting a de-cat pipe you still have to have the little sensor (heat exchanger sensor) plugged in an cable tied near the pipe, Otherwise the warning light will eventually come on indicating a fault. Some IMPORTED scoobies don't have LAMBDA sensors hence why such a nightmare for passing M.O.T emissions.
I take it this is a classic which i dont know much about but on the new age you use a 2.2K resistor either plugged into the car side of the plug recepticle or cut the sensor off, solder the 2.2K resistor onto the wires and plug back in - sorted? I assume the cat on fire system on the classic will work exactly the same, resistor will cost about 10p from maplins.
Sorry mate forget to mention was tallking about classic model. Dont know anything about fitting resistor? never heard of that approach before but sounds like a better way of doing things. also een told about fitting a MAGNEX de-cat pipe is the best way,stops you getting turbo turbulence!
