cusco kid Posted May 6, 2007 Posted May 6, 2007 hi guys needing some info about the g/box numbers q1 is it the white plastic lables on thel/h side on the bellhousing at the starter hole if it is which one denotes the final drive ratio q2 if not then where is it thanks geo[]
JohnSt Posted May 6, 2007 Posted May 6, 2007 George, yes it is. ID Starts TY7xxxxxxx The code does not use a sequence to denote final drive you just have to look the code up. Things that can be determined at a glance though are: TY752 Ph1 Box TY754 Ph2 Box TYxxxVNxxx 1:1.1 Transfer gears, (To be honest this also tells you it has a 3.9 final drive Ratio) TYxxxVBxxx 1:1 Transfer gears, (can be either 3.9, 4.11 or 4.44) P.M me your email address and I'll send you a spreadsheet containing all the box codes and ratios
