Where is the best place to get a replacement clutch.
Been reading re. clutch problems on here and mine is on its way out. Can anyone recommend good online shop to get new std/upgrade clutch, somewhere that can get me a good deal and not make a hole in my wallet, Also how much work involve in replacing them? Any help would be appreciated.
AWD do a standard replacement clutch and fitting for £450.I recently got a upgraded one fitted there and if thats what ur after then give them a call!
It's a few hours labour to replace the clutch and your best getting ur flywheel skimmed at the same time(or a new shinny ligher one),which AWD can also sort out for u.
Perth is a bit far for me to travel. Im from Aberdeen area sorry i should have mentioned it before. Is there anywhere i can get original clutch from apart from local dealer?
Funnily enough...............There is a place in Aberdeen that can supply and fit it. I know the guy really well :-)
BUT.......................................................
Don't underestimate the benifit of going to Perth if you feel it is best. Grant, Andy and the boys will really look after you
Russell
