rear box question ?
Bought a scorpion rear box off e-bay, the seller said it was for 03 model,  get home & looks like a classic fitment,
will it fit ok ? do l have to bend the front hanger or  grind it off & re-weld it on again pointing the other way ?
cheers  mark  [;)]
Marky,
If you can bend the front hanger through 180 degrees it will fit but tbh you are probably best to get someone to weld on a new one based on the box your removing. The other hangers are exactly the same for newage/classic.
 I know that the TSL group N box that I have comes with two front hangers (one classic one newage) and bolts so that you can fit on either.
Gus
Yip Marky, thats deffo a classic fitment[:S]. should be easy enoughto cut and reweld for someone with oxy tho as the hanger is simply reversed. or just re-sell it on here to a classic owner[;)]
cheers gus would it be easier to heat it up with the oxy & just bend it ?
I havn't got the new car yet, still on it's way from japan but trying to get the bits together so l can get them fitted straight away  [:o]
